brianpgriset
Quincy QT compressor. Ordered the proper HOA switch kit per the label inside the starter. I think I know what to do but want to check.
FYI I get continuity between yellow and black wires off the back of the HOA switch with "Auto" pushed and continuity between yellow and red with "Hand" pushed.
Remove "downstream" wire from pressure switch (currently at A1) and wire this to black wire. Land yellow wire on terminal A1. Land red wire on L1 (line voltage).
My understanding is this will put the pressure switch in front of the "Auto" push button, and will provide power to coil through yellow wire. With "Hand" depressed, this will bypass the pressure switch and jumper power directly from L1 to A1 which will in turn power the coil and run regardless of pressure switch.
Does this sound right? Also, this won't effect my overload protection right?
