So I don't claim to be good at all with electric but my house must of been wired by idiots. The left switch is a 3way and the right one is a single pole (that I cannot find controlling anything) these switches are located and the top of the stairs. The 3 way controls the light above the steps. At the far end of the hall is the only switch for the hallway.(which is also a single pole)
So the issue (s)
I tore apart the 2 3ways and now can't get it to work. I'm assuming I switched wires. The light works but the switches do not work in conjunction with each other.
Other issue is with the switch on the right they have a wire as u can see coming over from that to the 3way. From what I can tell it was a jumper they soldered in.
What in the world is going on
The 3way worked just fine prior to me tearing into it to update the switch
Sent from my SM-G930R4 using Tapatalk
So the issue (s)
