jpcjguy
Hi all,
So my lights came in and I have the Romex that also has the dimmer control wires. I have created a lighting pattern that will be either 20 or 24 lights on the flat part of the garage. (See pics)
I have a question on the process of the running the wiring. The lights are only 2.4" wide. I don't plan on having junction boxes at each light, since it would be a pain to frame up the exact locations. So how do I ensure that the wire is in the right place after the drywallers are done? The holes in the lights are tiny. Fishing them after the fact seems like a futile act.
Luckily the "bays" between floors will not have insulation (insulating the outer shell of the building), so I can easily run wires in the cavity, (but then they won't be secured along the trusses - ****, just though of that).
What is the best course of action here?
Spec sheet of lights: https://www.ledlightingwholesaleinc.com/v/vspfiles/Erythin/E5SLB_SpecSheet.pdf
