I've got a HUH724ST (manual says Marley, but looks like its marketed under several brand names). Is anyone familiar with this unit? Its the bigger brother to th HUH524TA (7kw instead of 5kw). I'm trying to wire a line level thermostat (Honeywell RLV310A) to control the heater. I pretty much just wired it so that the Honeywell is wired in the same place the stock knob was (knob is removed from the circuit). The thermostat seems to work fine until it tries to kick the heater on...as soon as it does it seems to 'reboot' (goes blank for a second, then comes back on). No clue whats going on.
Anyone familiar with this heater? I can try to post the wiring diagram if necessary. It seems like the manual doesn't exist on the internet. Its similar to the G73 everyone on here seems to talk about, but it has a 240V relay for the main lines and the thermostat is wired in so that it is what triggers the relay.
