breezluv32
- Joined
- Dec 22, 2011
- Messages
- 1
Hi everyone! This is my first post. I'd just like to say that I have found some great info on this site. I hope that someone can help me out with this project. I recently had a steel building installed beside my house. It has steel tubing for the frame with steel/metal siding, and sits on a concrete slab. All of the electrical will be exposed because I am not finishing the inside. It is about 20' from my house. I want to wire the building for a couple of lights and a couple of receps. I plan to run a new circuilt from my panel in the house (20 amp, 12/2 wire, gfci breaker). What I am having trouble with is the grounding. I am running pvc conduit to metal boxes attached directly to the steel framing. I would use a grounding screw in each box.
Question 1: Is this acceptable?
Question 2: Should I use emt instead of PVC conduit?
Question 3: Should I use plastic boxes instead of metal boxes?
Question 4: If there was a short, would it "energize" the entire building (framing and siding) since the boxes are in contact with the steel framing?
Any help is greatly appreciated!
