Wiring MR Heater 75,000
Relie
Western Mass
Most cities or towns require you to have an emergency shut off switch. I mounted mine right by the side door. When I am done in the garage and the heater has cycled down I just flip the switch to off, then when I return to the garage again I just flip the switch on. The furnace fan comes on and in a few seconds the sparky starts the furnace and I have heat. Makes it real easy to use the furnace.
Dave
Old Patriot
I just ordered a 75,000 from Amazon which was a damaged box special. They say all parts and everything is still under warranty, plus I have a no question return. Should be here today or tomorrow. I know what thread to go to if I have problems:thumbup:
jpearson
Hi - I'm new to the forum and I have a couple questions. I am currently installing the 75000 btu version of this heater. I have never done a project like this before.
My first question is not wiring related: My exhaust pipe is going to be about 4 feet long with a little over a foot outside my house. My question is - is it safe to paint the portion of the pipe that extends outside the house? Of course I would prime it but I would like to paint it to match the house. It wouldn't be heat resistant paint, just regular latex house paint.
My second question is where do I connect the ground wire? Can I connect it to any of the metal parts? The pos and neg connections are obviously marked but there is no obvious ground connection.
Thanks in advance.
Josh
rickairmedic
louisville ,Ky
Josh I wouldnt paint the vent pipe . The ground wire if there isnt a green colored screw ( I dont know havent done one of these units ) then simply put it under a screw near where the electric comes into the unit .
Rick
porcupine73
Buffalo, NY USA
I have this heater and I did paint the pipe outside the building. I think it was a high temp grey paint I used. It seemed to work alright, although it is starting to flake off in recent years.
dave67fd
Southern NH
If your using B vent pipe you could probably get away with painting it. I wouldn't though paint the terminator.
