Wiring my Bendpak XPR-10AS
oleblue
Good morning fellows, I got my lift stood up last night and all cables ran. Down to the wiring now. I have a black and white coming from the micro safety switch and a black white and ground coming from my 10/2 Romex. Then the lift push button switch has a black and white coming off of it. I’ve seen the wiring diagram in the manual and can’t make much of it. I’m a picture kinda guy. Do I just tie the whites with the whites and the black with the blacks? See the picture for what I have going on. Thank you for your help.
pattenp
Virginia - USA
The micro switch breaks one leg so it's wired inline on one leg. So you can hook black romex to black push button. Then hook white romex to white micro switch, then hook black micro switch to white push button. If it helps to visualize what's going on tape the black micro switch wire as white so you can see it is breaking the white leg. I am assuming this is 240V.
