taylormade
In my garage, I'm running a 6/2 wire for a 220 line from the 100 amp breaker box to my 7.5hp (peak - it's really a 5hp 23 amp motor) compressor. I have a 60 amp breaker on the line. I want to put a shut off switch in the line for safety. I bought one of the gray metal box on/off units rated for 60 amps 220 service. It has four terminals, two for the incoming and two for the outgoing, plus a neutral bar that you install inside by screwing it on through the back of the metal box. I assume I run the two neutral (bare) wires into the neutral bar, but does the box itself have to be grounded like the main box (wire to a metal stake outside?) I don’t think so, but this is my first 220 wiring attempt and I prefer not to be fried when switching on my compressor.
Thanks for any help you can offer.
RT
RT
