Wiring Question
ilikedirt
Northern VA
This is probably a real dumb question but how do I control the top outlet with the switch? I wired it up and both are constant hot?
The Cobbler
your hot to the outlet is not switched. to switch the upper outlet you need 3wire to the outlet, 1 hot switched( to the upper) and the other hot not switched ( to the lower ) and be sure to break the tab on the hot between the 2 outlets
I hope youre not using that diagram.
The switch has 2 power feeds- white taped black and the red.
And its a 3-way...
What are u trying to do? Control the light and outlet with one switch and have them alternate
justsam
Penngrove, California
Sounds to me like what you want is what is known as a "half hot" receptacle.
Your drawing is just a drawing of an always hot duplex receptacle and a light controlled by a switch, all fed from the same power source.
As stated by the Cobbler, you need 3 wire to the half hot receptacle, break the tab on the hot side of the receptacle, attach one hot, and one switched hot. Neutral and ground as usual.
http://knoji.com/images/user/outlet-half-hot-diagram.jpg
LS6 Tommy
Northern NJ
And its a 3-way...
That is not "red". It's the ground...
Tommy
