I'm finally getting ready to tear down the 1977 pole barn on my property and build a 1056 sq ft detached garage/workshop for my tools and toys. I'm planning to do at least the majority of the electrical myself and am looking for some advice on the wiring. I have a somewhat unique situation as my house has 400 amp service from the days when electricity was cheap (it was built in 1968) and it had two electric furnaces to keep the house heated. The "smaller electric furnace" as it's called out on the main panel was run from a 70amp breaker on the main panel while the main electric furnace was powered from a 100 amp breaker in its own separate disconnect panel that splits off from a CT box where the 400 amp service enters the house. Since that 100 amp disconnect is no longer utilized I'm hoping to use that instead of tying into my main breaker panel. The run from the 100 amp disconnect to the is approximately 75-85 feet, I plan to run conduit along the back side of my house and then go underground to the new sub-panel on the garage. Since I'm also planning to add a 7-9 kw solar panel setup on my garage roof the solar guy advised that I have a down-rated main breaker on my panel to meet backfeed requirements, so the panel will be a 200 amp 42 space panel with only a 100 amp main breaker. So my question is, for the run out to the sub-panel, can I run x3 3 AWG CU THHN for my hot and neutral legs in conduit or do I need to go with a thicker gauge? I'm finding conflicting info on the amperage capacity for what I'm proposing. Also what should I run for the ground wire?
Thanks!
Thanks!
