I have a Rockwell Drill Press with a 1/2 motor model 62-610 I would like to wire from 220 to 110. It has a diagram on the motor but I am to much of a novice to figure it out completely. Does anyone have a wiring diagram? Thanks
Piece of cake. If you look at the 115 volt diagram you will see TWO jumper straps. In the 230 volt diagram there is only ONE . It is that strap that goes from the upper left terminal to the lower right in your photo of of the motor terminal box. You are going to have to fabricate another one out of a piece of brass or put terminals on a short piece of heavy wire to make a jumper. The two black wires in the motor with the red terminals stay where they are. The metal strap that goes from the upper left to lower right must be moved to go from upper left to lower left. The new jumper, that you must supply, will go from from the upper right to lower right terminal. The power line can be put on the two screws that are not occupied by the two black internal wires. For neatness put the straps on first. Those internal black wires are the ones marked 7 and 8 on the diagrams. Need any more clarification, let me know.
It just occurred to me. Did they double up the two straps on one pair of terminals for 230 volts? Take a look before making another strap.
