I about to start a major remodel of my 2 building 1700sf garage/shop and I'm looking for some strategies to create some flexibility in the wiring. My past experience: Much planning and $$ goes into the outlet placement ....and .... it ends up being wrong .. especially frustrating with floor outlets. Most outlets go unused and you need double in some spots.
The newer of the two buildings is made out of structured insulated panels and was never wired. All the wiring will need to be surface mounted -- for those who have had to surface mount ..........what problems did you run into? I was thinking Emt at around 50" off the floor and branch off from that. I know the spot for the compressor -- so I could run a separate one for that.
The older building needs to be gutted. I am going to replace the concrete floor and have it spray foamed. It currently has a 100amp sub-panel and some electric. My thought was to install 120v outlets/ switches typically and then run wires for the lighting and any wires needed for the newer building prior to installing the walls.
This was my other thought: Install wainscoting around the perimeter of the interior with a 4" shelf at about 50" and either build a chase (preferred) under the shelf for wires or mount Emt and do as I am doing in the other building. What I don't understand is how is that chase treated under the electric code? The chase would allow me to install 220v outlets where I need them and then any higher up 120v outlets that I may need.
Thoughts?
Thoughts?
