NHBandit
First off I already tried doind a search and it only confused me more. Searching for things like "sub panel wiring" results in hundreds of threads that don't answer my simple question. So please bare with me and give me a simple laymans answer to my question. I have a 4 wire feeder wire coming into my sub panel in my detatched garage. I bought it at Lowes after reading several threads here about what to get and it's a 100 amp panel & it came with a couple 220 breakers and 3 110 breakers. Perfect for my needs. So today I'm wiring it up and there is no place to attatch the heavy bare ground wire. Pictures I've found on here and on Google show the neutral going to the large square spot on the ground bar so that's how I hooked it up. Do I need to go get another of those square adaptors and also attatch the ground to the same bar ? Also there was a green screw loose in the bottom of the box that could be used to ground that bar to the box itself. Do I want to do that or leave the box ungrounded ? Second question. I have a 100 amp breaker I bought for the main panel in the house and plenty of room for it. I have 400 amp service in the basement. When it comes time to hook up to the main panel do I also attatch the large ground wire from the garage to the neutral in the house as well ? Here is a pic of where I'm at. Thanks.
