OldsRocket
Is there any reason to not have wobble extensions only? Are they much weaker than standard extensions? If weakness isn't a factor I don't see the need standard extensions.
Wobbles are annoying to me.
The wobble extensions I have still look brand new. For some reason I avoid them like the plague and only use them when I absolutely have to. I honestly couldn't tell you why I dislike them though, I guess they have the feel of a worn out tool to me.
Wobbles do have their place.
Have some 12mm 13mm 1/2" driveshaft bolts that are torqued down to about 125ft lbs (spec but are usually much tighter than that)
Using a straight extension leaves the extension tight against the driveshaft tube, no room for impact. No way in hell a chunky universal/swivel would fit in there. Even the drive end of the socket has scars from rubbing.
You are right. Friction also comes into play, but the angle is the main concern.Regarding torque, I think its the angle, not just that its a wobble. Anytime the angle isn't straight the torque on the fastener is reduced, but I could have it all wrong too.
That's what I was thinking. Maybe I need to draw a free body diagram and crunch the physics LOL. Since the Ford Techs would have had a lot of time working on those intake elbows, there may have been a tech bulletin issued to them from engineering. I didn't have a wobble on mine when I put mine back on one time. I didn't use a torque wrench then either. It was really only a pain on one bolt though, and I torqued it based on feel. Since it was aluminum, I didn't torque it too tight -- just snug. I still remember that hard lesson from a Datsun 280z inline 6 many moons ago. A wobble would have been very nice though on that one bolt. I need to get one.Regarding torque, I think its the angle, not just that its a wobble. Anytime the angle isn't straight the torque on the fastener is reduced, but I could have it all wrong too.
If you happen to want to sell them, let me know!The wobble extensions I have still look brand new. For some reason I avoid them like the plague and only use them when I absolutely have to. I honestly couldn't tell you why I dislike them though, I guess they have the feel of a worn out tool to me. Not that it matters but mine are Snap On.
I have never owned a flexible socket extension or flexible socket driver. Are they really worth it? Have you used them successfully?As always, the only correct GJ answer for "which tool?" is "all the above".
Which is perfectly true in this case. Sometimes you need wobbles, but they're weaker, and sometimes a wobble won't keep things in alignment. For example, you need to get a bolt into a hole, but sort of lever things sideways to get the bolt started so the part will line up. Can't do that with a wobble.
I'll toss a third variant into this: sometimes you need locking extensions. For example, spark plugs down inside a deep, dark hole. Locking extensions can be a little weaker, and sometimes access is so tight there's no room for the locking mechanism, so now you need three kinds of extensions...
And a fourth, flexible extensions... probably more I'm forgetting.
Wobbles definitely have their place, but too much torque will cause them to break. I've broken plenty using just a ratchet. Also I've never had any luck with the darn socket retainers, sockets just fall off them. I have learned that a good universal joint socket adapter will do much better than a wobble extension.Is there any reason to not have wobble extensions only? Are they much weaker than standard extensions? If weakness isn't a factor I don't see the need standard extensions.
