Gentlemen (and ladies),
I have a 2 story house, primary heat is via a natural gas-fired furnace. The original owner installed a wood burning furnace in the basement (see the attached pic) and never used it. It does have the required separate flue and works well. The WB furnace is not connected to the existing NG ducts, it simply radiates heat into the basement and, in turn, the heat radiates up into the first floor of the house. The basement does have insulated walls so it gets quite hot when the WB furnace is running. I have an unlimited supply of free, dried, hardwood to burn.
I’d like to improve the efficiency of the WB furnace. I plan on installing sheet metal around 3 sides of the WB furnace (the top and 2 sides), the sheet metal would have a 1” air gap (or so) from the WB furnace surfaces. I would install a 6” round duct from the existing return air duct to the top piece of sheet-metal installed on the WB furnace to draw hot air from around the WB furnace. I’d also install an in-line 6” 240 CFM fan within the round duct to assist in hot air flow.
This arrangement would draw air around the WB furnace and into the return air ducts. Both the in-line fan and existing NG furnace blower would be controlled by the heat sensor installed on the WB furnace, so the fans turn on automatically when the WB furnace has wood burning in it. The NG furnace would turn on normally when additional heat was required as determined by the thermostat setting.
All the parts would amount to about $75.00 and a few hours of work by me.
I’m doing all of this because I don’t think passively radiating heat from the WB furnace in the basement and into the living space is efficient. I know that some of the heat is wasted by heating the basement walls, floors etc; and, the basement is essentially unusable by me when I’m burning wood as it gets too hot to work in.
Given the low cost of the project, do you think this project would be worthwhile? Do you see any safety issues ? Has anyone done anything like this ? Thoughts ?
Thanks.
Joe
Thanks.
Joe
