Wood countersink bits
mhejl
DFW Texas
I also like the single hole KEOs. M.A. Ford and KEO single flute work well, too.
Multi-flute never work well for me in wood and cause chatter marks and tearout.
legenddc
I have a cheap set maybe from Sears but will be purchasing a Amana Tool countersink when I have a project that needs a lot of counter sunk holes. They're expensive at around $40 each.
acer66
Western North Carolina
I have my I on one of these but I am a bit concerned that the stop could mar the workpiece.
Dave455
Sussex, England
I don’t generally buy countersinks designed for wood, a lot of them just seem to be made out of poorer steel.
I just use a metalworking countersink. Don’t need to go top end. I use these Ruko ones as they are inexpensive where I am, but there are many options.
I do use them exclusively for wood, so they stay sharp, but the edge retention is superb.CAE427E5-72AF-41D0-BA78-AE548D69667D.jpeg
If you are doing repetitive work, then these Festool combined drill bits and countersinks are awesome tools, as they have a depth stop so each hole is the same. You can adjust the drill bit back, and just use them as a countersink if needed. FFC8AFE9-B542-43C8-8301-EE6C7D65BE6C.jpeg
