Wood deck over concrete?
Mopar_Ray
I have a concrete porch. Approximately 8"x 7". The concrete is pretty spalled. Been thinking of building a deck over the the concrete vs replacing the concrete. Looking for ideas about how about attaching it?
Zeke
Just set concrete piers in thinset if you can build up. Otherwise place joists slightly above the concrete for drainage and attach with various L brackets and Tapcons. If you have only a little height available you will install boards on the flat called sleepers. You can use fasteners directly through the face but you still need some space for drainage. Some will use asphalt shingle pieces to lift the boards. Use PT lumber in all cases under the deck itself.
On thing here is that you can build the deck level whereas the concrete most likely slopes. Crud will accumulate under the deck so make it so you can clean underneath by blowing or hosing or both.
wburke2010
why not just use a concrete grinder and grind it back smooth. I am sure there is a rental store around you that will have one. We get about 100 bucks a day for one and you could use the weekend to your advantage to grind it and just have one day for rental. Would be a lot cheaper than building a new wood deck and it would still be nice concrete that wouldn't rot.
Walter
Mopar_Ray
I don't think grinding would work, the concrete is 37 years old and is weathered enough that the aggregate is starting to show?
Kevin54
MEMBER EMERITUS
Urbana, Ohio
I built a deck over a concrete porch probably 25 years ago, and it is still there today. The concrete was in bad shape, so I put down 2x6 sleepers (joist) and added the deck on those. It made for a nice solid deck.
Mopar_Ray
Exactly what I was thinking of doing. Only problem I see is my stoop is 7" tall, if I add a 2" sleeper & and a 2" deck it will be 10", too high of a rise and sure it wouldn't make code. May require a different plan.
NUTTSGT
Northern Central Ohio
How about a picture or two ? They generally help out leading people in the right direction as far as advice goes.
NUTTSGT
It appears as though it has settled down a few inches. I think I might consider tearing it out to make sure there is no water damage or anything to the foundation.
Mopar_Ray
Not sure if it has settled, at least not in the last 11 years I've lived here, the space between stoop and doorway has always been there. Some of what you're seeing between brick wall and stoop is caulk that badly needs to be redone. House sits on a full unfinished basement and shows no signs of any water damage in basement?
NUTTSGT
I was looking at the area behind the toy. If you follow the brick line.
tcianci
Walpole, Ma
Armchair engineer warning!!!
The Op has accurately stated and illustrated the site conditions. Your "settling" is simply the pitch to which the concrete was finished when it was installed. On this planet, water runs down hill.
NUTTSGT
I'm quite well of water running down hill and appreciate compliment of armchair engineer coming from you.
I'm not there is person but I did ask for the OP to show us a picture. I'm merely trying to make the sure the OP doesn't have an issue that he needs to be worried about and that he is looking at the same thing that I'm looking at it the picture. If he has no issues, that's great news.
BTW, if the brick line is level, it appears that way, the distance behind the toy to the corner appears to grow, to me.
Zeke
I finally looked at the pic hard enough to see that the porch was finished like that on purpose. It's a technique we are all familiar with called exposed aggregate. The finisher sprays a retardant or sugar on the surface and waits 2 hours to wash the fat off exposing the aggregate. A light muriatic wash further brightens the stone. It's a perfect surface to do almost any of the suggestions here so far except tearing it out. Just clean it well beforehand. Lots of mold and dirt lives in the pores.
The world is your oyster.
Homerr
Seattle, WA
I have a similar situation and recently snapped a pic of this porch as an idea of what I'd do to my place.
