Wood Fabrication
I've used Raka epoxy http://raka.com It seems to be the best price.
I'm bookmarking that site !
Just curious, which resin and hardener did you use ?
Ever try the "no-blush" hardener ? (Blush is a waxy layer that forms as most epoxies cure. You can get most of the "blush" off by wiping with acetone but for best result, you must sand between layers to ensure proper adhesion for the next layer of 'glass and epoxy.)
T
trainer
Northern Ontario, Canada
I used the no blush for fiberglass layup and clearcoating. It's very slow to set up. I've had great results with it.
I also got a pint of fast hardener for quick glue-ups and smaller jobs. It'll heat up and melt the mixing cups if your not quick getting it used. Raka lets you get several different kinds of hardener in an order without charging a premium.
cnc-me
MI
Here's what I have been doing in my garage all winter.
11' long wide transom canoe designed to be hauled on top of an ATV.
Made of cedar and epoxy with oak trim. Seats are hand caned.
I designed and built this from scratch
Simply outstanding work here!
You be careful when hauling that on the ATV.
I think it needs to be hauled to a museum or art show. :)
To nice to use......
