I put a used outside woodburning furnace in my shop when it was built back in the early 90's and when we installed it we put the return air down low and the exhaust air up about head high. They are stacked. Conventional thinking and normal gas or electric furnace install is opposite. Its been so long since we did it I cant remember why we chose to do it this way. Should I change it to return high and heat low or is it okay like it is? It heats well but it does seem to take a while to heat the shop, however I dont keep it going all the time, the shop is 30x40and insulated with 1/2 inch foil back.
