Wood steering wheel repair
AldeanFan
Niagara on the Lake
How would you fix this steering wheel?
This wheel is going on a friend’s golf cart. It doesn’t have to be perfect, but I’d like to make it better. And there isn’t really a budget so I’m doing it on the cheap.
The wheel is riveted together so I can’t really take it apart.
I’m an ok woodworker but not sure how to approach something like this.IMG_7046.jpegIMG_7047.jpegIMG_7049.jpeg
ALinCarolina
NC Piedmont
The epoxy would work well. I doubt you would need any wire, epoxy will bond very well to the open wood. Epoxy putty wouldn't even need a dam.
If you want to stay with real wood then I would cut the void to straight lines. With a pull saw and a sharp wood chisel. Then glue a somewhat matching species of wood in there, smooth with chisel, plane, sandpaper, stain and finish. Epoxy would eventually degrade from UV light so if outside all the time I would coat it.
The Cobbler
for a paint grade repair, I would use bondo
for a semi matched repair, I would cut out the chipped section , chisel the bottom flat leaving as much base mat'l as you can . fit a pc of wood in to the cut out. glue it in place, clamp tightly. let it full cure. . Plane, carve , sand /whatever to match the profile . stain/finish as you wish. It looks like pine, so it would be easy to work with
A
AldeanFan
Niagara on the Lake
Thanks for the suggestions,
I’d like to keep it wood looking so I’ll probably try to cut is square and glue in a piece of whatever wood I have that somewhat matches.
If that doesn’t work I can always epoxy and paint.
Monza Harry
Windsor ON
AldeanFan, I like the idea's above, if I'm reading them correctly. I wouldn't cut it square, just make the angled break flatter to make a match much easier without squaring it off. I would drill some "porcupined" small (1/16" dia. x ⅛" Dp.) holes in each piece for the glue to interlock into. Harry
Skiff Builder
Southern NJ Coast
Looks like a piece of half round stock would work well.
I'm all for epoxy mixed with fine saw dust as a gap filling glue. I like Harry's idea on the holes- with a counter sink you create an epoxy rivet.
budget76
send it to me instead, I'll fix it :)
first thought was teh same as yours. square it up, glue on a piece of something, then rasp/sand it to shape. Shouldn't be too hard
budget76
in all seriousness, if that's a bolt-on style and he decides to replace it, the patina on that would look good in my 68 IH pickup project. I'd be interested in it
post up the repair after either way :)
Fixr
SW VA
Repair has started,
I’m working on a video for my YouTube channel as I go and I’ll post a link when it’s done.
Nice!
The patch piece of wood looks considerably more interesting than the rest of the rim. You could make up a story about the provenance:
"This patch was taken from the last remaining fragment of the wooden pegleg that my great great great granduncle Long John Silver wore..."
A
AldeanFan
Niagara on the Lake
Nice!
I’m going to tell people it was an original piece of trim from my Country Squire woody!
It’s actually part of a broom handle from Dollarama. I cut the handle down to fit the broom in my trailer lol
