Wood stove glass !!
firecracker
Lancs UK
What do you use to clean the door glass on your wood burning stove????
Thought I'd get your recomendation before attempting my new install.:bowdown:
Rye425
CT
Cook top cleaner works the best. Glass cook tops of course.
toomany
Auburn, Mi
Wet paper towel and some of the ash from the stove works best on my wood and pellet stoves. Windex or other like cleaners are bad for them, will eventually develop a haze. And...I believe it's actually a ceramic, not glass.
jjpp
michigan
As others have said ash on a damp paper towel is best. Cleaners will damage the gasket over time and they are messy and will stain the hearth.
Ash can be used to polish and clean just about anything.
jjpp
michigan
Oh ya, and the build up on the glass should be minimal if your stove drafts properly and you are burning good DRY, hardwoods.
Outlander
Quebec, Canada
Reading this thread I looked over at my wood stove and figured I would give it a try. Last time I removed the door and used nasty chemicals outside. Yes, the wet paper towel dipped in ash from last night's fire works!
rustyjames
central nj
I was pretty skeptical when I read about using the ashes too, but it does work great. I learned about it from hearth.com which is the website for everything related to wood burning.
