Wood Users: Scrap Lumber. What Do You Keep? Throw Away?
PastTense
When you do various projects using wood there is scrap left over: some pieces large, other pieces quite small. Anyone care to comment on what your policy is as to what you keep vs what you throw away? (I notice I have been keeping very small pieces and am starting to think that is a mistake.)
Thanks.
rsieracki
Chicagoland Area
i use blueprint file cabinets to separare by species and types of wood (pine oak, plywood, 2x4 etc) i do the same thing with metal and plexiglass etc... but i keep way too much ****. plywood chunks get layed on the shed/shop attic floor or slid behind some file cabinets i left 6" from the wall for this purpose
TommyD
Yeastern CT
Depends on the wood and the size. If I have larger pieces of wood that I can make the smaller pieces out of it goes in my firewood box. If it seems to be a useful smaller size it gets kept until I get too many the same size then it goes into the firewood box. 2x's, 4x's and the like, the same judgement.
Stuart in MN
Minneapolis
The smaller they are the more likely they will be tossed. A few years ago I filled a small dumpster with wood scraps I'd been saving for no particular reason, and I haven't missed them.
Jere
For cheap wood like softwood 2xXx if the section is 3 or feet or more i save it. Hardwood is about the same but i save thinner sections ie pallet planks. The longer pieces get stored in the rafters and the shorter sections are on a high shelf in between totes . If there wasn't a good storage solution i wouldn't keep as much around.
Highbeam
Mt Rainier foothills, WA
More than three feet it stays (board) and plywood if more than two feet in both directions. I have really appreciated the left over plywood of varying thicknesses. Sometimes you only need a little 4x6" square of 9/16" thickness.
diver165
West Virginia
If the scraps won't fit on my wood cart it's gone. I try to estimate my material needs pretty close. So I usually don't have tons of stuff to get rid of to be honest. I learned years ago. Keeping a lot of that stuff around eats up storage space and makes your shop look like hell.
brycez28
Sheboygan, Wisconsin
I pretty much keep everything that is 6" or longer. Anything less than 16" goes into a drawer that I use when I need small blocks of wood for something. up to 2.5' goes on shelf under basement steps. longer than that goes on a wood rack I built to try to reduce warping for future use.
Smaller untreated (and non-plywood) pieces gets put in a bucket and burned the next time light up my fire pit. Treated and plywood goes out with my regular garbage.
Jere
I have quite a bit of scraps presently as I'm taking a break from Woodworking due to hopefully a move out of state. My local refuse company will not take building materials so other than just putting them out on the curb in hopes of someone needing and grabbing them, I'm not sure what to do with them.
Motoretro
My local trash company says the same thing on their website. I just load up our one trash can one week at a time. I have gotten rid of a roof load of shingles and endless cans full of cut up treated or rotted lumber this way. I didn't even use bags just made sure the lid closed and that was it. Worst case scenario if the company gets picky is to bag up cut up stuff. Its not like they are going to search through trash bags.
kaymccampbell
Upstate New York
Warped, split, or smaller than my fist go in a milk crate and then up the dumbwaiter to the livingroom for heat. I will be saving the smaller pieces this summer as I want to try my hand at making an acoustic panel for the wall behind my compressor.
ssdave
Eastern Oregon
I keep oak scraps in almost any size over 2" in any dimension. I keep a few pine scraps if they don't have knots. However, I only keep a shelf full in my shop, when it gets more than that, i fill boxes up and put an ad on craigslist to sell a couple boxes for $10. Toymakers and such will come and get them, as they need small pieces anyway. They'd rather pay a few cents a board foot than $2.80.
I buy wood for projects rough cut, random width/length. I pay the supplier an additional $.25 per bf to plane it both sides and straight line rip one side. When I rip to width, I keep all the rips that are 1/4" or more in thickness. I use them for edge laminating plywood shelves and such, and use them a huge amount for shims when clamping things in the vise. I just break them into 18" long pieces and pile them on a shelf near the vise. Wider rips I keep for planing 3/4" or 1/2" square pieces for craftsman type furniture and railings and for laminating up to make stuff. I always go to the smalls pile to shop when i need stuff instead of cutting a wide board.
When I was installing doors, I used the rips for shims when installing frames. An assortment of widths would work better than using softwood wedges.
The primary use I have for small scraps is testing cuts using the router or partial depth cuts on the table saw. Easy to experiment on the same exact wood as the real thing, and see how the cut works or how it looks or see if the depth is set right.
If you do a lot of woodworking, you will always have way more scraps than you need. If you only do projects intermittently, it's good to keep scraps for small needs in between.
dave
rburke65
Canfield, Ohio
I am fortunate enough to have a pole barn and I keep more than I should, but i find myself digging out a piece of 2"x or what ever. Trash n treasure. Lots of the small stuff goes to the wood burner for supplemental heat.
diver165
West Virginia
Wow a roof load of shingles? And I thought I had patience. I remodeled my house and put ceramic tile through out the house. I had a ton of tile trimmings and construction debris. The trash men took every bit of it and didn't bat an eye. The key is to treat them like humans and make it easy for them. Bundle stuff up or box it up to make it easy to load.
I did pay to get rid of the carpet. LOL. I didn't want it getting wet while waiting to feed it into the weekly trash
