Woodcraft
Falcon67
Merkel, TX
Some other handy stuff out there - search turned up Carpenter Cut. $10, not cheap. Put your plywood cuts from a 4x8 sheet in it and the app will gen a cut layout for the sheet.
david594
Makes me wish I owned an iPad. Temped to get it to try it out on the iphone though.
DekeT
USA
I am surprised the chopsaw operator still has a thumb. Do people actually do that?
Sarbatche
Rocky Point, NC
The machining industry has been crying for a tool like that since the first iPad was just a rumor. Of course, we'd like it use different materials than wood and dimension things like tapped holes, bevels, etc... Then ultimately be able to port directly to a CNC machine.
Very cool app, but I'm not sure that it would more efficient than just pencil, paper, and calculator.
Velbain
Mtl
Ouarf,
:lol:
iPad is already obsolete, that are tools of future :
trojandj
I took a look at this and it is nice if you have trouble visualizing objects in 3D. It allowed me to "use" the piece I wanted to make it for a little while and then make modifications.
Thought I would share the mobile wood cart I had planned with you guys. I have been lurking here long enough. Take a look at Doug's Mobile Wood Cart in the woodcraft galleries if you are looking for a place to start. I did add a 2x4 on the top of each side after uploading the plans.
NitroPress
Aurora, CO
I haven't built much of anything in the last few years without drawing at least some working plans in CAD. You make all your mistakes and work through all the options in empty space and then can build the widget the right way - concentrating on the work and the finish instead of on details like strut lengths or hole placement.
Most recent thing was a heavy-duty tripod trolley that I wanted to fold - I could work out the folding leg pivot points to the fraction, so when I built it, they fold precisely flat against the others. It was meant to be a quick fill-in project but I've carried it on several location shoots and it always gets comments and compliments. Fun.
So yeah, I recommend even a simple sketchup or CAD program as a tool to start projects. Time to master the basics will pay off over and over.
Nitsuj
Am I just reckless? It didn't appear that close to me, considering the tool. It looked to be about 1.5 to 2 inches away, and on a chop saw, the work piece is stationary that the blade only moves up and down. Seemed a little close, but risk is minimal. It's not like that blade can suddenly jump to the right. IMHO.
