GLHS60
Hello All:
My first post, I found the site while searching for info on sealing older wooden door panel gaps.
I have an older Tudor style house, built on a hill, with a small garage that is essentially in the house basement.
It has a very low ceiling and two separate wooden garage doors, each with a typical over head electric door opening system and low headroom track.
My main issue right now is draft entering the garage between the wooden door panel gaps.
I saw a post recommending foam strips between the gaps, installed from the outside. Sounds reasonable.
While I have good mechanical skills automotively speaking, I'm not very savvy with wood in general.
I probably really need new doors but they will have to do for now.
I'm going to tackle the door drafts as soon as its warm enough to try the adhesive backed foam.
Any tips either way would be appreciated!!!
Thanks
Randy
Thanks
Randy
