Woodworkers, what is your way for scribing?
BioNerd
Undisclosed location in the middle of nowhere
For example, an edge of casing to a wall or baseboard to floor...
I've seen people do it with grinders, jig saws, table saw without fence, rasps....
My way is block plane and 100grit sanding block, I precut that edge to 30 degrees and use a compass to get close, then erase the line and eyeball the minute adjustments.
If possible I screw in an angle to squeeze the piece tight using trim head screws.
I don't like walking around to make adjustments, I made myself a 1 1/2 x 3 feet shooting board/step stool that I carry around in the site.
I just added a jack plane to take less time removing material and leave the detail for the block plane.
cyato
Orange County, CA
I don't know if this is the kind of feedback you're looking for, but as far as for making the line/mark in the first place, I use this tool.
http://www.m-powertools.com/products/perfect-****/perfect-****.htm
When the gap is tighter than what this tool allows for, I use a drafting pencil with a smaller router bearing.
There is also this tool for certain situations.
http://toolmonger.com/2009/10/09/scribe-with-a-router/
Precutting the edge to 30 degrees is a good idea: Idea Stored in Brain. :)
mjozefow
Lafayette, IN
Block plane and rasps. I used to use a belt sander, but realized the block plane is easier.
I use a Lie-Nielsen apron plane mostly.
