pauls_workshop
Question for the woodworkers. Didn't intend to, but I managed to acquire two different 6" jointers in the last year. I can only keep one and need to sell one of them. Which to keep and which to sell and why?
I have a "Cleveland Industrial" Taiwan made clone of the Rockwell (now Delta) 37-220 jointer, with open cabinet. "Cleveland Industrial" was not apparently a real company and has nothing to do with any "real" cleveland company, but what the clone had slapped on its label. It was from about 1983 or so. Has a 3/4 hp motor and generally in good condition. 6" size. Has a long fence on it, about the same as jointer number 2 below... Runs at about 5000 rpm. Has a little slight surface rust, but some wd-40 is now covering it well. This is one heavy machine, all cast iron. I can't add a photo of it at the moment as it is buried in my garage! It is very much like the real 37-220 here but with a more flimsy open cabinet on it:
http://www.normanmachinetool.com/us...d=WOODWORKING_EQUIPMENT_ROCKWELL/DELTA_37-220
Also now have a newer Jet JJ-6OS. A picture of it is here:
http://www.gotgreattools.com/jet-jj...jointer-1ph-two-way-tilting-fence-708455.html
This sold in the $375ish range in the early 2000's at Lowes and similar places. It is similar 6" size, same 3/4 motor size, 4850 rpm, in very good shape without any rust or issues. Also made in Taiwan. The Jet is 46" bed size vs 48" on the delta clone, almost the same. This is a similarly heavy machine, a little lighter than the delta clone. Basically, a bottom of the line Jet offering as best I can tell.
I don't have a means yet to measure/inspect fully the details of the bed/rails in terms of precision. Assuming both were of similar and good precision, which jointer to keep and why? Which to part with? The Jet is newer and parts are available for it. The one I have had little use and was used by a construction firm (not really that much need for construction guys to joint/plane wood). The older delta clone has lots of total use but spread out a little over many years but no issues. A farmer had it but only used it occasionally who I bought it from. I got that one first, then ran across the jet recently and couldn't pass it up for the price. What is a fair value for each, in very good used condition for the mid-west (indiana)?
Just for comparisons, here is a rather uncannily similar thread where another asked some similar questions to mine:
http://www.woodworking.com/forum/showthread.php?10920-Old-Vs-New-A-question-on-Jointers
And here is (on the whole internet) all I could find about the delta clone jointer:
http://www.engineeredbyme.com/projects/6-jointer-upgrade.aspx
Thx all for your opinions on this one! - Paul
