Work Bench for Shop
Steve9681
I am planning on building a 4'x8' work bench with a butcher block top. Does anyone have any ideas or plans they can share?
LopezBart
Lopez Island, WA
I'd look on-line; you-tube is full of nifty workbench designs. It's really mostly an aesthetic process - what do _you_ like? If I were limited to wood, I'd probably grossly overbuild the workbench w/ 6x6 legs. Since you're building it from wood and using a butcher block top, I assume you're going for mostly woodworking projects. Figure out what tools you want bolted to the top/sides - vice? drill press? You likely want some overhang on the edges for clamping; you may want some square holes for dogs.
Check out
looks neat.
ez-duzit
Marina del Rey
Butcher block would be an extremely poor choice for a workbench top. You want edge grain--not end grain, if using solid lumber. But tempered hardboard is more practical.
My 4' x 8' work/assembly bench (lower left) serves also as the offcut table for dual table saws.
rocksnstumps
A 4 x 8 assembly table makes sense or as shown for sheet goods for around table saws. The classical woodworkers bench made from solid wood and having a bench vise and and spots for bench dogs is typically smaller. Maybe 3 x 6 or even a bit narrower like 30". So what is the intended purpose of this bench? Does it have to remain relatively flat? A 4 x 8 wood surface is gonna take some framing underneath to prevent sagging. Again if some sort of solid wood strips/blocks/planks need to consider wood movement with fastening to the framing underneath.
A bit more on intended use would help with others meeting your intended vision.
Steve9681
This work bench is going to sit in the middle of my shop and will be there for multi purpose use. Not intended for specifically wood work or car repairs. Just looking for something with plenty of functionality that is sturdy and mobile.
Firebrick43
West central Indiana
This is the best stout cheap bench I have seen. Its a woodworking bench but you don't have to make the tool till or put the vises into it.
Made with 2x lumber. I would suggest screwing a piece of tempered hardboard smooth side up on top as a sacrificial surface and wax it.
https://picnicpark.org/keith/woodworking/workbench/BobAndDavesGoodFastAndCheapBench-ne.pdf
I have built 1 woodworking style bench and 3 regular benches but in the same construction manner. They are super strong.
A piece of angle iron across the end of the legs can hold a pair of ratcheting casters at both ends. The extending ratchet arm makes it quick and easy to lift the wheels off the ground and make a rock solid footing or lower the wheels and roll it to where you need it.
rocksnstumps
If you really want to keep this at a 4 x 8 size and keep it mostly flat, suggest you search here and Google for torsion box table or torsion box build. If you want a substantial feel to your top slap on another laminated layer to increase the thickness as most of these designs are focused on stiffness but keeping light weight. They tend to have tops that are 1/2" or less.
MushCreek
Upstate South Carolina
I learned how to make stout work benches from a guitar maker. The legs are a 2X2 or 2X4, but the secret is the plywood outer legs that really stiffen it up. It's also important to glue and screw everything together. For a bench that big, I'd add a set of middle legs.bench.jpg
jives
Central NY
Sitting in the middle of the shop as an all purpose bench precludes this as any form of standard woodworkers' bench. It will eventually be used for assembly, parts/tool holder, perhaps an outfeed table, and so forth. If truly 4 x 8 (that is some hunk of expensive butcher block) it will likely have on it more than one project at a time. It is also likely that it will be exposed to glue, paint, stain, varnish, oil of all types, greasy grime, cleanser, hammer strikes, chisel gouges, and whatever else. Are you sure you want the BB (edge or face grain) to be exposed to that?
I have two primary work tables. One serves as the table saw outfeed table. It is an old formica office work desk with two pedestal legs. It works great, and for the $5 it cost, it was a no brainer. I added wheels and spacers to raise it up. This table takes on most woodworking projects. In the pic below it is being used for another "random" project, this time the repair of a car top bag. It is aso to store the miter station. The next table is an old steel tanker table (not desk), that is 32" x 60". Removed the crumbling vinyl top, replaced with a sheet of 1/4 steel. made a rolling base for it with shelf. It has two drawers but I never use them, the the shelf is indispensable.
With that said, a huge BB table in the center of the shop would be a proud showpiece.
Steve9681
Guys, I read thru all of your comments and attachments. You all gave good advice and now I have a few things to consider. Thanks for your help.
u2slow
BC
IMHO, a 4' deep work surface is too deep to have against a wall. (I'm a spindly 6'3" with a good reach). 36-42" is about the max.
Jack Olsen
Los Angeles
I have a few butcher-block-top benches, including one in the center of my garage. I think it makes a great work surface.
All of this is subjective, of course, but 4x8 is a fairly unwieldy size, and benches that roll don't appeal to me at all (again, speaking personally).
I put some multi-drawer cabinets under mine. Usually, most of the space down there gets wasted.
Firebrick43
Butcher block is end grain up. Its done to allow disinfectant and UV light to sterilize the surface. It make for really lousy workbench tops as it has no significant strength due to grain running 90 degrees to the typical load path of a workbench top.
MovingAlong
Have you considered a Ron Paulk torsion style box/workbench?
Hooked
League City, Texas
Thank you for the link to those Ratcheting Casters.
