Work Bench Top Protection
lilredex
Toronto
Paint would be nice, and maybe 3/4" ply under it if you intend to do any real work there.
wizness
Houston TX
I used hard board. Works good and super easy to replace. I would add more plywood honestly. Half inch is pretty weak but good luck.
zkling
I would not use plywood for a work surface. If you insist, a good sanding and a coat of poly. Topping it with a piece of MDF or hard board would be a better idea.
QtrHorse13
TX
I use textured HDPE. It has a slight texture to it and is very dense. It is what food cutting boards are made out of. It is resistant to most chemicals that a typical workbench comes into contact with. It is harder that plywood but costs more. You could get the smooth version if you prefer a smooth surface, HDPE SR. The only thing I don't like is that your choices for colors are limited to white or black in most cases. You can get colors but they cost more and are harder to get.
torqueman2002
good idea, but finding it is another dilema.
I am lucky to live in SE Michigan, where there are many industrial suppliers.
I Googled conveyor belt and there are 3 with in 15 miles.
Here are some offered on eBay.
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p4712.m570.l1313.TR0.TRC0.H0&_nkw=conveyor+belt+material+used&_sacat=0
To secure it to the bench, I used drywall screws with finishing washers.
velocipede
Yorktown, Virginia
Right now my bench has a tempered hardboard (Masonite type) top, sealed with shellac, which wears so well it's never been replaced. I do a lot of woodworking and actually keep the hardboard covered with disposable red rosin paper from the BORG which can be easily replaced if it gets too greasy from some wrenching job:
http://www.homedepot.com/p/Trimaco-36-in-x-167-ft-Red-Rosin-Medium-Weight-Paper-35145/202040751
Recently, I was in tow with the missus and noticed this on sale at JoAnn Fabrics and bought it on a whim:
http://www.joann.com/36x59-cutting-mat/2622033.html
Got home and read mixed reviews. Apparently, you can't trust the accuracy of the markings, but I think it will serve my purpose: Impervious to most liquids, will take a beating, won't tear easily, can be cut on and used to help align parts and should be an easy clean up. Time will tell.
Canuck76
I like bulk roll red rubber gasket material.
Chemical resistant and wears well! A little contact cement holds it in place.
Whiskeymike
Austin, TX
I used hard board. Works good and super easy to replace. I would add more plywood honestly. Half inch is pretty weak but good luck.[/URL]
x2. I then cover the hard board with packing paper so I can throw it away after it gets dirty. Also handy to write measurements, do math and draw something out. I also don't mind using a razor on it when trying to cut insulation from a wire or other purposes.
The nice thing about the hard board is that it's smooth and cheap so you don't mind replacing it when it get's beat up.
I like the idea of a metal top, but I have a welding table so the hardboard is a nice alternative for things that need to be a bit softer and non-conductive.
Davefr
OR
Use the PVC flooring tiles intended for garage floors. (Metal is to slick):
