TMcCay
I have been putting off building the cabinets/workbench corner in my shop because of being undecided on the material for the top. I have an opportunity to get a room full of oak flooring and have been thinking it would make a suitable top for these cabinets/benches.
Has anyone used this for a bench top. The bench will be for woodworking and leathercraft. I thought the oak should be tough enough to stand up to the abuse that it will be facing. I am wanting a minimum of 1 1/2" for a bench top. This leaves me with either machining the bottom of the flooring flat and using 2 layers or more which there should be enough for this. Or cutting the tongue and grooves off, machining both sides for a flat surface and laminating the wood together to make the top.
I have plenty of experience with wood in general. I will need at least 36 feet of surface for the bench top. So has anyone done this? Any advice on proceeding? Suggestions are appreciated.
