I recall seeing the Limmer shop when vacationing in Intervale, NH a few years ago so I just looked them up; they have a 2-3 year backlog wait list for the shop made boots. Wow.top four brands:
White
Limmer
Danner
Wesco
Anything else is second-tier. They are all crazy expensive now. ($519.00 MSRP on the Wesco Jobmaster now.)
I bought mine about... 2000 or 2001 so I could work a gig up at ONP. (Required an 8-inch fire boot.) Had my cobbler put a plate in front of the heel on mine so I don't cut the sole in half kicking a shovel. YMMV.
We no longer tan leather in this country, so OF COURSE they're going to be "made in USA of Imported materials".
I have some Chippewa boots that use either Vibram Cristy soles, or maybe a similar sole from some other manufacturer.What you're describing may be Polyurethane Hydrolysis. It's a common issue and there are lots of discussions about it but here is one article I found quickly. Even if it was actually the rubber outsole that was degrading, it worth noting that PU Hydrolysis is almost an inevitability for boots where the sole is bonded to the boot with a PU midsole. You can delay it with proper care and storage, but not prevent it entirely.
One solution is to look for recraftable boots where the sole is stitched to the midsole/upper with (for example) a welted construction. There are various methods of achieving this most boots marketed as "recraftable" will be able to have the soels replaced many times over the life of the boot.
The drawbacks are that PU midsole does actually add some desirable comfort to a boot, and lacking such a feature, you will need to opt for a softer sole (Christy or similar wedge sole) or add a cushioned insert to achieve similar levels of cushion.
They send you a pair to try out?I have Nicks boots. On my first resole after 8 years. Use them all my waking hours of the day and they are like new. All I do is clean them with soap and water once in a while and use boot grease and heat gun to soak it in. If I remember right they were around 500 dollars and they sent me a pair of try on boots to test for size and now they have the pattern if I order more
Your observations are exactly correct. Blown rubber soles (the general term for soles of this construction type) have relatively low traction compared to a hard rubber sole (which is why they are not often found on hiking boots), and are fast wearing compared to a hard rubber sole. And yet, they are among the most popular options for work boots, particularly goodyear welted boots.I have some Chippewa boots that use either Vibram Cristy soles, or maybe a similar sole from some other manufacturer.
The soles were comfortable, but durability was way less than the hard black rubber Vibram soles I’ve had on boots in the past.
The durability was lower by years.
I can’t say for certain that the soles were Cristy soles, but they came on USA made Chippewa Heritage line boots, and the parent comoany for Chippewa uses US made Vibram soles on a bunch of their other USA made boots.
The Chippewa “Cristy” wedge soles also sort of sucked for grip compared with Vibram lug soles.
I would not really recommend the soles unless you want to pay for frequent resoles, and don’t mind the lower traction.
Red Backs, Best boots I've ever ownedTry Red Back boots, made in Australia. I have 2 pairs.
yesThey send you a pair to try out?
first Nick sent me a kit on how to measure the feet and trace the foot. After reviewing this they selected a boot that they sent me to try on and then called to work through how it fits. Based on that they finalized the fit and made the boots and shipped them to me.They send you a pair to try out?
Walking my dogs in crappy weather. Wear the heels out at an angle due to bad ? posture? Upgrading to recraftable for my next pairWhat do you do that you can wear the soles out while the upper stays good enough to consider having new soles put on?
It looks nice, but $185 is pretty close to what a new pair of similar USA made boots might cost.Your observations are exactly correct. Blown rubber soles (the general term for soles of this construction type) have relatively low traction compared to a hard rubber sole (which is why they are not often found on hiking boots), and are fast wearing compared to a hard rubber sole. And yet, they are among the most popular options for work boots, particularly goodyear welted boots.
Why? Because they are light, and comfortable, providing an almost sneaker-like feel underfoot without the requirement for a cushioned midsole. So yes, you will have to replace them more often than a hard rubber sole, but at least you can replace them without replacing the whole boot, which is not always possible for hard rubber soles bonded to a PU misdole (that being another popular option for achieving comfort).
I don't think it's hard to understand that there must be a compromise in durability for comfort. Yes, you can have a leather boot with a leather midsole and leather or hard rubber outsole, but standing on it all day is not comfortable for everyone. However, if you don't spend all day on your feet, or if you are lucky enough to be able to wear a harder wearing sole without discomfort, a blown rubber sole is not for you.
I will say that there are varying degrees of durability among wedge soles based on their composition and construction. For example, I find the Christy sole to be more durable than Vibram's own 2021 wedge sole. I don't have personal experience with many others but there are opinions out there.
Edit: I should have mentioned that there are cobblers who will give you both by installing a wedge sole, sanding off the lugs, and bonding a hard rubber sole to the bottom. This results in a taller stack height than just the wedge and of course it's heavier, but offers both comfort and durability.
Not cheap though!
Here is Fred's take with a Kletterlift.
That may be true but I'm not aware of many (any?) factory boots available with a lugsole over a wedge sole. I'm sure you could custom order some from somewhere but now you're talking big money again. Might as well have it done to your favorite uppers that you've already broken in to your preference.It looks nice, but $185 is pretty close to what a new pair of similar USA made boots might cost.
My dad had a pair of Galibier Super Guides, talk about heavy and stiff, even by ‘70’s standards. Well built boot though.^ They wear out walking on trail surfaces. I've had my Galibiers re-soled three times now, the Wescos once. The soles just wear off when you're walking and climbing on rock or working on trail.
Galibiers were purchased January 1976 for $125. (Almost a month's rent then.) Good leather and magnificent construction.
Not really suitable as a "work boot", however, as they are engineered to have a fairly rigid sole to help with edging or to be worn with a crampon.
But even the high-carbon Vibrams will wear out after several years of service.
Finally found the second photo taken just after the last resole.
here's where to order
Got the new Danner R. A. T.'s. Per your suggestion. As soon as I put them on I knew they were keepers. Immediately ordered another pair for $79. That'll hold me for awhile! ThksI almost bought a pair of Thorogoods last year just to give them a shot. I've stuck with made in Portland Danner's for almost 20 years for the simple fact that they hold up very well. My favorites are the RAT model and seeing they are surplus you can pick up a pair on Ebay for less than $100. Not bad for a $400 pair of boots.
Clean with some good saddle soap, then oil/shine/polish the leather as appropriate. The bonus to all this is it also increases the water repellent qualities of your leather as well. I can assure you diesel based drilling mud and the soupy red clay dirt and gravel of north Louisiana and the small boulders of granite and chert they built pads with in Oklahoma did not do mine any favors while I was in the oilfield and they are just going strong as ever. Take care of your boots and they'll take care of you.A question for folks: What do you do that you can wear the soles out while the upper stays good enough to consider having new soles put on? I wear work boots daily on the farm. Plenty of time on gravel, but a lot on dirt as well. The uppers on my boots usually give out before the soles. Crawling around or working under vehicles es is pretty rough on mine
Alright.... So what are the economics I can come up with to justify a trip to South Africa and convince myself it practically paid for itself in savings in boots....Hey, a bit of a follow up. I have 7 pairs of Jim Green now. Visited South Africa in December and decided to buy two more pairs... One is a one-off custom Chelsea style stockman (cost me around 140$) and the other is a pair of Numzaan boots which cost me around 160$ in South Africa.
The Numzaan are a beast of a boot, they are made of partially veg tanned uppers that I assume will age into a beautiful patina, they are fully lined with calf leather, everything is triple stitched, and there is a massive slab of thick veg tan leather for the lasting board. For what I paid in South Africa, it feels like a steal. For sure the stitch lines aren't as straight as one might assume they'd be from really pricey brands, but the quality is just about as good as it can be.
Wanted to post some photos but the wifi right here is too bad. I just watched a new video from Jim Green and it makes me proud to support this brand, the director is just such a cool person and a stark contrast to the fast fashion disposable world we live in today.
Trip is worth it, the nature is spectacular, the people overall are quite kind. Their biggest banknote is worth 10$, so practically everything is considerably cheaper than in the US or in Europe even when you go to pricey places.Alright.... So what are the economics I can come up with to justify a trip to South Africa and convince myself it practically paid for itself in savings in boots....
Wow! Sounds incredible! You already had me convinced at the low cost boots.Trip is worth it, the nature is spectacular, the people overall are quite kind. Their biggest banknote is worth 10$, so practically everything is considerably cheaper than in the US or in Europe even when you go to pricey places.
Plus the wines of the Stellenbosch region are world class. They've got a wine tram that takes you through the vineyards for the whole day with wine tasting included with the ticket.
They make some Gedore tools there. I took a 10mm wrench as a souvenir. The quality is sadly not that great, even a bit worse than what I expect from German Gedore, but it is the same name (not red).
I wanted to grab the acetate handle Wera screwdrivers that are also made there, but I didn't see them in any stores and didn't want to pay for shipping. Those seem seriously cool.
Hey, a bit of a follow up. I have 7 pairs of Jim Green now...
jimgreenfootwear.com
I wore some Belleville desert boots for several years but it got to the point that the sole was just too damn hard.
I about bought a pair once till my buddy showed me his pair. His son had bought him a set while stationed at Camp Lejuene.You can buy Danner RATs for cheap and they are way better than Belleville.
Do the Jim Green Stockman boots have the big logo on the back?
That is what has stopped me from buying the Shoelies. I really dislike big logos on shoes.
Years ago I had a Tucker Gunleather holster, belt, and magazine holster made without logos. He got a bit fussy about it.
I've had my eye on a pair of the barefoot rangers (bronco) for awhile now and am going to place an order. A question for you - do you use the leather insoles in any of your boots? If so, are they worth getting right away, or do you think it'd be worth seeing how the boots fit first?
Footbeds - Leather Lined - JG/STC Last - Jim Green
Styles of boots to use with the JG/STC Footbeds/Insoles Standarn African Rangers Barefoot African Rangers AR8 (All Styles) Tyre Wedge Numzaan boots Barefoot African Trooper Rugged African Trooper Standard Stockman Barefoot Stockman Vellies Barefoot Shoellies Razorbacksjimgreenfootwear.com
Thanks!
