Workbench I designed and built
srvctec
Central Kansas
I designed and built this workbench about 10 years ago. It's over built like a brick sh!thouse, but I'd rather have too stout of a workbench than a wimpy one. It's probably strong enough to set a small car on top of. I have no idea what it weighs, but if I had to guess, probably around 250 pounds. The top is made of an old bridge plank planed down to 2 1/2" thick, cut in half and bolted/screwed together. The dimensions of the top (determined by the size of the plank) are 23 5/8" wide by 59 3/8" long.
Here are the planks planed down and held together with a couple pieces of 2" x 3" 3/16" thick angle iron and a piece of 3/4" oak in the middle to keep the edges aligned.
I filled all the low spots with wood filler since we didn't plane the plank down perfectly on the bottom because it wouldn't be visible. I used shellac to seal it.
Some more of the 3" x 2" angle iron to hold the legs in place, painted and ready to install.
The legs are made of 4" x 6" treated lumber since that was all I could find in that size (didn't really want or need treated). I installed super heavy duty cast aluminum locking casters with a hard rubber tread.
The bottom installed. This reminds me how much of a challenge this build was. I had no plans except for what I had in mind when I started. The plans evolved as I built the bench. The biggest challenge was building the whole thing upside down.
Starting to install the drawer slides. I work on copiers for a living (since 1988) and when we toss super old machines, I take what I want off them to use later. All of the copiers had full extension ball bearing slides for the paper drawers AND they were Accuride brand (I have a box full of them).
A closer look of the bottom. The 2" x 2" all around the edge is what the sides and front and back will be screwed to.
The drawer made to fit (sorry, no pics of the drawer by itself).
The back installed. Sides, front and back are made of 1/2" plywood.
The front installed.
The sides installed.
The interior.
Almost finished. Notice on the front that the door covers the drawer. I made it that way so I could cut the top of the door off and attach it to the front of the drawer and all the wood grain would be seamless.
As it is today- just took these pics yesterday and today for the messy workbench thread. The finished height is 33 7/8". The overhang on the ends is 10" and on the sides is 1 5/8".
ttimpe
The interior.
Nice write up
srmofo
SW ohio
When I first saw that door in front of the drawer, I thought "thats not going to last,lol" then a few pictures later the door is cut down.
How sturdy is it with just the vertical legs? Typically that makes for pretty terrible joints in wood but with the brackets on every side I dont know
astroracer
Mid_Michigan
The lack of "cross-bracing" doesn't matter and the brackets are a moot point. With the lower shelf and the plywood sides plating everything together the legs are going no where.
Nice job! All of my work benches but one have casters and I wouldn't have it any other way.
Mark
NUTTSGT
Northern Central Ohio
For the OP request, I have deleted some excess pics out of the quote. When somebody quotes an entire post with a ton of pics, it makes it hard to read for the other members scrolling through the post. It's reasons like this, I recommend that members only put a few pics in a post and make multiple post. In the end, it's a matter of to each his own.
I noticed the overall height is less than 34". Kurt, are you a shorter fellow ? Just curious as that would kill my back working at a bench that low. I know work bench height is a topic that comes up occassionally here on the forum.
astroracer
Mid_Michigan
I agree. There was no need to "quote" the entire post for a three word response. Please use some common sense when replying.
Mark
srvctec
Central Kansas
Well, I arrived at that height (basically 34"- only 1/8" less, most likely due in part to the compression of the rubber on the casters since it hasn't moved in a few years) by doing research at the time and 34" was the standard height. I actually wouldn't mind if it were a little taller since I'm 6'1" and my metal bench has risers making it 41" tall. Hindsight is 20/20- can't really remember if there was another reason or not why I chose that height since it was 10 years ago. :)
srvctec
Central Kansas
Mark
Exactly. If it weren't built the way it is, there is no way the angle iron brackets would have been sufficient to keep the legs plumb. Of course, using the brackets was way overkill, but the sucker is so solid, it's crazy.
scottcorn
I am looking to replicate a top similar to the one you have. Was the bridge plank creosoted?
don long
southern california
Very nice project. I like having my tools a grab away ( I don't like to walk any more than I have to)
My first thought was whty the block on the bottom of each leg?
After reading through the thread my thought changes to why not add a taller block onto each leg if the bench is too short.
Continue enjoying the fruits of your labor
Don
ambenz
NW Chicago Suburbs
I like the drawer underneath...I am gonna add a few drawers under mine as I have a lot of full drawer slides just lying around....thanks for sharing your ideas!
