Workbench preference
Before you ask a generic question, you might want to give clarity to what you are doing. Woodwork, auto repair, welding, watchmaking.... they all have radically different needs from a bench.
Shiftless
East Bay SFO
Quite a few of us just built their workbenches from framing lumber and plywood.
That way you can have the exact size you want and what best fits the space available and suits the kind of work you do in the shop.
If you do mostly car repair, use a double thickness of 3/4 inch plywood with a sheet metal top.
Or keep you eyes open for a piece of steel plate. Used or scrap cut offs from a bigger job.
Mark in Indiana
Southern Indiana
I prefer steel legs and a wooden top. In fact my welding table has a steel top that I fasten a wood top to it when I'm not welding. Keeps work pieces cleaner, in my experience.
Professional Tool User
BC
My personal preference is wood. I built my work bench out of 2 by 4s, a thick particle board, and screws. I remember spending less on building it than a cheap bench. The cheap work benches like the ones at Harbor Freight simply didn't feel beefy enough for mounting my bench vice. If you make your own, you can build it to your quality standards and custom needs. You can easily put a piece of sheet metal or rubber matting on top if you want. Wood is relatively easy to work with if you already have a drill/hammer, a circular saw, and some measuring tools. Drilling holes through metal (if bolting parts together) and welding complicates things.
Kscardsfan
The Little Apple
The family handyman basic workbench plan is stupid easy and can be modified to fit your needs on the fly. I’ll try and find a link here in a bit.
joshmodelskidoo
mid western michigan
I have an old wood workers bench with a wood working vice on it and i also have a store baught one that was used for a desk at Home Depot, its got 2 drawers and a couple shelves. I had a home made one from plywood and 2x4s at my last place that worked just fine. You can always cover a wooden bench with tin or steel later. You can always use the top of a big tool box to
GerMec
Best workbench surface for me is a conveyor belt. Doesnt scratch anything and robust
dwasifar
^^^ This for me.
Jagmandave
Overland Park, Ks.
I have both, I like each for their purpose, when building an engine or transmission I like the metal bench. I have my bench grinder bolted to my wood bench, it's quieter and dampens vibrations. If I only had one I would have the metal one as it's tougher and can handle more weight.
I like the conveyor belt idea for the top tho.....
anndel
Hawaii, USA
Ditto. I use my toolbox top and built one from Steve Ramsey's Wood Working for Mere Mortals called the Basic Mobile Workbench.
BTL-A4
Santa Clarita
Make or buy one with a metal top. I had a wood top and then started working on my car and the oil, grease, etc. ruined the wood top.
I got a piece of 16 Ga cold rolled steel and had the supply place cut it to size for me. My bench is 8 feet long and 24" deep, so I got two tops out of it. The place I bought the steel charged me for the whole piece, so I took the whole piece.
I also have a sheet of rubber that I use as a mat. I've used a piece of hardboard (1/8" thick, like pegboard without the holes) as well.
I made my bench so that I could fit tool boxes under it for storage.
1982fxr
Phoenix
Anything available used in your area?
Sometimes you can find exactly what you want and it saves time. Material costs are insane right now.
CJM8515
wood bench stained with poly is no issue. for years i worked on all manner of things and it hardly made a dent in the poly.
Mr_B
Reading
wood benches out of framing timber and ply are easy for anyone make , steel box or angle is nice and allows for slender frame and more design scope .
as for worktop hard beat thick rubber mat or even tempered hardboard laid over ply .
good for almost all usage beside heat and top surface easy and cheaply replaced .
steel plate is nice but be more cost and bit more marring.
Would avoid stainless as not worth the cost .
If want drawers underneath part of it half height filing cabinets work great and can be next to free off local classifieds ...
Lucid Moments
Gainesville, Ga
I built mine out of 2X4's and plywood. Since I did it a couple of years ago I probably have less than $50 in the whole thing. Will cost more with today's lumber prices, but still less than anything you can build.
Ilikeike
Northern Ca.
Basic car repair. I'm looking more towards the metal top than wooden top.
Car repair = metal is best.
Wood is for... well,. wood hobby's, or guns, your wife's crafts, etc...
When I'm working on delicate stuff like my firearms, I put a padded felt piece on the bench.
Jswain
Calgary, AB
I went this route as well. My welding/cutting table has a portaband on one side, a small 4 inch vise on the other, and a slip on plywood top that locks in on both sides.
All on lockable casters. Small garage anything that can do double duty is a win win
mercifiknow
Somewhere I should be
I have the HF. I got it for Christmas a few years from wife and kids. Not good for anything except maybe electrical work as I’m OCD some.
I gave a old grainger workbench with thick wood top on it. I’m afraid to do much on it so I will use hardboard when working on car parts.
