LinuxMercedes
I've got a workbench I made from some 2x4s and a 4x8 sheet of MDF. It's 4' square and has a lower shelf. I have a vise mounted in the corner with some extra bracing in place.
Unfortnuately, the bench isn't really heavy enough to hold a vise in place for any sort of hammering or whatnot. I used a couple of air compressor motors as a weight on the bottom shelf to hold it in place, but I eventually want to do something with those.
I'm going to be adding some diagonal bracing (it has none currently), which should hopefully at least keep the table from twisting whenever I hammer anything on it. Do you think that will be sufficient to keep the table steady? If not, what are good ways to keep it from moving around when I'm working on it?
