BoostedOne
So I am looking at revamping some of my "shop", which started out as a simple pole barn that was slabbed and had walls added.
One wall is still unmodified. It was an area that was 2 horse stalls.
One of the things I want to do is remove that area all together. The roofing is getting thin, the ends of the rafters and first purlin are rotten from not being protected when it was installed by previous owner.
I am wanting to enclose this area. I know normal wood framing methods I would normally use to accomplish this, but I have been looking into light gauge steel framing. Note, I am not talking about red iron and tubular steel construction. I am referring to the light gauge framing that comes in normal 2x lumber sizes, which uses different gauges of steel depending on the location.
I am getting a pretty decent feel for how to "build" with it, but the part that is stumping me right now that I am having no luck is how you attach certain things to it.
The one that is really getting me is attachment of a garage door(panelized, not roll up). Normally you would have several king and trimmer studs, and then your 2x6 jambs vertically screwed to them. Then the door track brackets screw through the jamb down into the studs.
I am figuring this cannot possibly be a sound approach with the steel framing. Even if I use a wood 2x6 for the jamb, at some point the load path is going to go into the flange of the studs, which is somewhat thin. The long Tek screws get several inches of thread in wood.
Note this is also a high wind zone. 140-150 mph.
Maybe I am not coming up with the correct search terms, but I have been looking online the past few days and finding no information.
THANKS!
THANKS!
