Workmate rescue!
greenlizard
Chapin, SC
The other day I tossed some junk metal into the box at the local dump. I glanced in and spotted a B&D Workmate. After a guilty glance around, into my truck it went! I've never actually asked, but I think it's a no-no to remove stuff from the dumpster. However, I couldn't let this go to waste. An original alloy frame Workmate without damage. It wasn't even folded up so whoever tossed it did not know what it is. A little paint splatter, a little dirt, ruined wood tops but otherwise great condition. This thing is too good to go to the crusher. When the weather warms up a bit I'll power wash it and then decide if it needs a repaint. Will probably make new tops from hardwood, maybe ash. I have an all steel model I bought in 1980 that I can use for a pattern.
fullthrottle24
Wow, great find. Those alloy ones sell for big bucks on eBay. I hope you can put it to good use instead.
oldtinsmith
Auburn, Mi.
Great find! I've got one just like that,(I bought it new years ago! Guessing about +/- 1970?) and even works as great as it did new!
Doug
Jagmandave
Overland Park, Ks.
I've bought two of those alloy ones locally on CL, paid $20 for one and $25 for the other......
But be aware, those are a different height than your later all steel workmate, that's why I wound up buying two of them - when I got the first one home I realized the difference from my steel one so I "had" to get another so I'd have two of the same height.
You can make new boards, but you can buy new factory replacements pretty cheap - $14 for the set IIRC.
Edit: Just looked at Ebay for "aluminum workmate"....yikes, they were asking $399 for one, and $295 for two others......both of mine are nicer than either of those $295 ones!
G
greenlizard
Chapin, SC
Hmm. I didn't realize the replacement boards were still available. The factory plywood boards are well-made and very strong - better than I could make. I'll look into that. Thanks for the info.
rick carpenter
Huntsville, East Texas
You may want to consider using softwood for the tops. It will be a little grippier. And if you fasten any jigs to it or gouge it with a chisel or whatever, it will be cheaper to replace.
Journaler
Nice find. I've been looking for one of those things for a long time now, congratulations!
senlow
Wheat Ridge, Colorado
Cool find. I believe your Workmate was made in the mid to late '70s. Black & Decker switched to the steel base in about '75. They moved from the aluminum frame to steel in about '80. It's amazing how light the all aluminum version is.
gatewaysysop
Arizona
Definitely a nice find, and the price was certainly right. :thumbup:
I have an older one of these, not alloy framed but similar vintage. They are awesome pieces and extremely useful. Glad you saved it from the scrap heap.
Jagmandave
Overland Park, Ks.
OOps, looks like I was off a bit on the price, more like $50 a set! Sorry bout that.....
