dubber
Nice progress with the insulation and shelving.
Looking good man! Cool score with the anvil...I like that.
Thanks Dubber, gotta get it finished up before it gets too cold around here.
Its coming! Mornings are starting to require jackets. That's always a big step for me once i finally give in to their necessity haha.
Very nice garage. This is a great example of efficient design strategies within a single car garage. This is going to make one hell of a shop. This is great! I read through the entire thread, and I may have missed it, but are you thinking on installing gutters at the eaves? This would also help your water issue greatly. You can even connect your down spouts to the perforated drain pipe you installed earlier.
Great to see the hand drawings as well. Either yourself or someone in the family is an architectConveying an idea in your head and quickly sketching it out is an art.
I really like that welding table. FYI you can drill and tap that thick table top and use this kind of clamp to hold your work pieces in position.
http://www.grizzly.com/products/4-1-4-Hold-Down-Clamp/G9590
You can also use the kind of clamps designed for mills and large drill presses.
That's a great vise. Too bad about the busted jaw. Hopefully you can find some replacement inserts. That grinder would make a great addition in a larger shop.
Good work on your place.
Best Regards
Herb Spencer
Place looks great and I am in Durham region too....epic free finds man! Keep that up. I am wondering - are you able to step on the metal roofing as it lays on the rood without damaging it? I just bought a new place in the shwa with a detached garage and will do the roof eventually just as you have. My first garage was a single and I did lots of work in it and it fit my 1966 skylark just fine...
Awesome job! Really making the best of anything!
Love the shop and its progess. Great finds and doing the best with what you got I can always relate with. Keep up the good work.
Nice to see the additional progress. This continues to be one of my favorite builds on this forum. Thanks for continuing to update your progress.
You must have picked up the anvil at Harvest Antiques on Taunton a few weeks ago. I had it in my hand to buy, but decided I didn't want to paint it. I noticed somebody else eyeing it and it was probably you. Small world.
I like the progress on your garage so far.
Dave
Very cool thread, I enjoyed reading your progress so far. I have an almost identical setup except my garage is cinder block construction...same worn out shingles.
I will be venturing down this path shortly as my garage also needs wiring, I'll be using a siemens 60A panel with similar underground conduit. My only hurdle so far is cutting through a cast concrete sidewalk in the backyard that leads to my patio (also cast concrete).
My only criticism/tip for you is to ditch all of those plastic outlet covers and replace them with the stamped galvanized type. I plan on using the metal ones for a variety of reasons... the plastic ones break very easily, the metal ones will literally last forever, they will look great (kind of industrial), and they don't show dirt nearly as much as the plastic type (if that's even a concern). Plus they're not much more $$$ compared to plastic.
Keep on keepin' on! I'll keep my eye on this for sure.
Are you going to put some vapor barrier over the insulation and line the inside?
Great use of space. I have a 16 x 20 shed that is way over crowded. You and Jack have giving me some motivation to reclaim some more floor space.
I know it's way too late now. But why didn't you throw a tarp over or put down that tyvak down on the roof before the rains flooded you three times? $40 in tarps would have saved you a ton of headaches.
Really neat build of a small shop with a lot of stuff, and potential. Are you going to put some vapor barrier over the insulation and line the inside?
Ric
Nice work on the garage. Great to see a small, well thought out space taking shape. Going to enjoy watching this one come together.
I'm dealing with similar space (12'x20') -- there's plenty of room if you think things through, and you seem to be doing a great job visualizing what you can do with your space. Great sketches.
Great thread. Can't wait to see how it turns out in relation to your (brilliant) sketches. It's always nice to see the 1-car size garages get built into quality shops. Isn't always about the sq. footage, and you're certainly proving that.
Nice...subscribed.
I was wondering the same. Great build, subscribed.
I don't know if it's been said, but I would take some of those more 'final' sketches you did, and frame them and hang them up when your place is all complete. I really like the sketches.
