Had some time over the weekend to start into a few of the pressing tasks that have been building up for a while. I continued my wainscoting all the way over to just past the end of my cupboards (about 8' so far), so that sucked the pile of pallet wood on my floor down a bit.
View media item 38595
I then used a few scrap pieces of wood to mock up the cap rail and 6" band that goes around all the outlets, and started mounting the pegboard supports to the wall. I ran a support along the bottom, middle, and top of the pegboard, with the provision along the top for another piece of 6" trim (mainly because my sheets of pegboard weren't big enough to go to the ceiling.
View media item 38596
To mount the pegboard, I used small flat headed screws and cup washers to make it look a little more purposeful. Note that the grey colour is the way they came, I would like to paint the pegboard a darker grey.
View media item 38597
I plan on building a shelf that will hang from the pegboard right along the back of the door track, since I can't really hang much up there anyways. Most of what's hung on the boards now will get re-assigned once all my boards are up. this area will be for axes, crowbars, and other long handled tools. As a side note, I plan on ditching the current rail hanger and lagging the rail straight across into the stud, using an appropriate spacer of course. This should help gain me a little more room and not break the flow so much.
View media item 38598
Having stripped the pegboard above the workbench, I took them both back down (they were only temporarily there anyways). I will be building cupboards across that region with peg board below.
View media item 38599
I stripped the wall to the side of the main bench as well, and hung a cleat for one of my new cupboards, and set about building it. I love how fast I can build these now with my new sliding mitre saw. I used to have to clamp a guide and use my circular, so I'm happy about this. I haven't tried yet but I could even dado the joints to add some strength (the saw has a depth-stop for doing dado cuts).
View media item 38600
View media item 38601
That's where I'm at now. I only had time to just get a few screws into the cupboard to hold it up, so I have yet to finish hanging it before I fill it. I plan to have a shelf in the middle of this guy too. Hoping to continue the cupboards along that wall this week and get the place tidied up more. It's nice now that the weather is being a little more co-operative and holding around the freezing mark, makes working more comfortable. The added hour of daylight isn't bad either. Spring, here I come.
In other news, I recently acquired a nice Stanley 8Gal Shop Vac from a good friend when he upgraded. So far I had been putting my wife's upright vacuum through tasks no domestic hoover should face, so Jay, thanks a bunch, this guy will really help out. Also, I'm a fan of the design of it, since it's nice and compact, being a bit taller than it is wide. This should help with storage, etc. I also dig the stainless canister.
View media item 38602
