Workshop Garage lighting question, looking at fixtures
First post, but have been lurking for years.
I engineered a second garage into my driveway during my new house build last year, and am looking to finish it out the second garage as a workshop. It is underneath my driveway, with 12" thick 12' tall concrete walls, and 10' steel beams supporting driveway slab above. It was a bonus feature of engineering a decent driveway turn-around for a driveway on a sloped lot, and avoiding having 12' of fill under my driveway.
Anyway, I am considering using Lithonia 8' T5 High Output fixtures from Home Depot (TZR 2 54T5HO MVOLT 1/4 GEB10PS):
Home Depot fixture link
with 5000k bulbs (specs showing 4800 lumens per bulb)
Room is 272 sqf (~25 m^2), with the 16 x 4800 lumen bulbs, will this be enough light output for a workshop? From what I can find on the web, with an approximated coefficient of utilization of .54 and a light loss factor of 0.8 (from other examples I can find for t5 HO fixtures/bulbs), this should give about 1327 lux. I am planning on re-wiring the ballasts with two switches to allow for running half the bulbs at a time to cut the light output in half.
Based on this example calculation site, I am approximating this:
I = 16 (4800 lumens) (0.54) (0.80) / (25 m2) = 1327 lux
(or 663 lux with half of the lights on)
Questions:
- This is my first attempt at calculating workshop illuminance, basing the calcs from other threads and web searches. Are these calcs reasonable? Would a reflector on the fixture improve the utilization coefficient?
- Is this a reasonable level of lux for a workshop (with all the wall concrete with the exception of the 8'x7' garage door, no natural light penetrates)
- Cost wise, the T8 fixtures are not much cheaper, and with the additional fixtures/bulbs to make the same lux, it seems like a wash, with the lesser fixtures being cleaner. Any advantage to having more T8 fixtures, vs the T5 HO fixtures?
- color temp wise, I was looking at going with 5000K, as 6500K seems too blue. Any cons of 5000k vs 4100k?
- for affixing the lights, I am looking at using 1/4" beam clamps to secure rails perpendicular the the beams for securing the lighting fixtures to.
Thanks,
-Brian
Questions:
Thanks,
-Brian
