xtal_01
Hello everyone!
I am just about to start building a new workshop ... well as soon as the weather breaks ... 4 last night ... 15 now but feels like -1 with the wind chill (Jericho, VT).
I have a 3500 sq ft pad of concrete poured.
I know now it would have been better to go with a frost wall and pad but was talked into a mono pour by three contractors.
The pad is 16" deep on the edges and has a ton of re-bar in it. It has 2" of foam under it and poly.
Still it has several cracks ... thus I can't simply put a row of block around the outside (tried this once before on a pad with cracks .... cracked the blocks or joints right where the cracks were). The pad has not shifted where the cracks are (still level on both sides ... probably because of the amount of re-bar) but I am sure it is moving a bit.
So, I have a few options.
I was going to just put down a piece of PT (pressure treat) and then build the wall and stand it up .. thus a single piece of pressure treat as a mud sill.
Then the farmer came over from next door. He said he would put the PT down and then also use a piece of PT for the bottom of the wall ... thus a double PT sill.
The I read a post where the guy went nuts and put down two pieces of PT as a mud sill! He then stood the wall on top of that saying he didn't want to have to use galvanized nails when building he wall.
Just to add to the mix ... I got in a piece of Bear Board ... plastic wood. You can get it in a 2 x 6 .... should I be thinking about using it as the mud sill? not cheap at $3.75 per ft but ???? I am a bit worried as it is plastic ... not sure if it will deform over the years ... but the sample I have is solid as a rock ... I have always been told plastic lasts forever ... and it will never see sun.
Tried to to put in link ... didn't let me ... bearboardlumber (dot) com
Just totally confused .... the more I think about it the more confused I get. Trying to make less mistakes on the shop than I did on the house.
Thanks ....
Thanks ....
