mschoo92
Hello everyone,
Back in 2022 I purchased my current home. I had two “non-negotiables” going in to my search; I needed a flat driveway, and I had to have a garage. Months of searching, countless open houses and several overlooked offers later and I found my home, sloped driveway and not a garage to be found…
I’ve attached a sketch over the property survey showing the current layout of my yard (also several photos to help visualize the space). The driveway extends past the side of the house (where ironically the main entry door is, hence the “front” porch annotation). I have a relatively clear space beyond driveway to the backyard - there is currently a 10x12 shed that is in decent condition and is where I store everything. There were also a metal shed and vinyl shed on the property corners when I purchased the house but both were in poor condition and have since been removed along with the “hedge row” as shown in the sketch. Fortunately I do have a basement that can serve as a workshop, but anything related to car maintenance or even larger furniture projects have to be done outside.
Which brings me to my mental project over the last couple of years; how can I maximize use of this space to serve as a workshop? A little background on me, I am a diy-er and try to do as much as I can myself. I work on cars regularly, and as much as I’d love a big shop with a lift I don’t see it happening anytime soon given the constraints I need to work around. I’m looking to build a space where I could wrench on my car, and if possible also have room for at least furniture assembly.
Here’s where I’m looking for suggestions. Given the space I have to work with, how would you approach this? Some options I’ve considered are as follows:
1. Be satisfied with what I have now, utilize the 10x12 as a tiny workshop and level out an area of driveway so I have a flat space to work on car. This will require me getting a second shed to put mower, lawn tools etc so that the shed can be a dedicated tools/workshop space.
2. Build a garage between the vinyl fence and leach field. One unfortunate part of buying this house was the septic failed. When the new system was installed, the leach field takes up a giant portion of the back yard. Before this my original thought was to build a detached 2 car in the rear corner of property, but with the leach field there and only 20ft between that ship has sailed. What I probably could still do is build a 12x20 or possibly 12x24, but talking to zoning this will require a variance as side yard setback is 15ft, and I believe 5ft from leach field.
3. Erect a carport, possibly in conjunction with option 1. Gives me a covered space to work, still would require a variance but may have more leniency versus a permanent structure like a garage. Never used a carport before so I’m not sure how feasible it is as a workshop type area, but this could also serve as a covered area for entertaining so I’m thinking it could be nice.
Of course, these are just the options I can think of and I’m open to suggestions - frankly I’m hitting a mental roadblock when it comes to making use of this space, and while I don’t think this is my forever home I don’t see myself moving anytime soon either. With that in mind, if you needed a place to serve as a workshop with these limitations, how would you approach it? Thanks in advance!
Lot sketch:
Front of house from street
Rear of house
Rear right corner where “vinyl shed” and “hedge row” used to be
Lot sketch:
Rear of house
