Dutch01
Hi, I would like some advise on how to repair / fix worn splines on a steering shaft where it attaches to the steering box. it is the female section with internal splines. Fastening to the male splines of the steering box is similar to the kick starter / gear shift on a motorcycle. The female section is welded to the steering shaft.
I noted that the groove that closes up when tightening the bolt had no gap. I grinded the groove a little bit wider to get more grip when tightened, but it only helped for a short while - damage was done. The car in question is a 1964 Austin Healey Sprite.
Obviously I do not want to compromise on safety.
Thanks - Andre
Thanks - Andre
To be honest I did tried that. My photos do not show the side I drilled and tapped the female section and screwed in a grub screw. It only helps for short periods of time and only when I need to move the Healey
For the love of all I could not drill through the steering box shaft. In fact there is no sign of the slightest indent where I attempted to drill
