I have the 12000e I believe. I have set it up twice. I took it with me when I moved. I learned from the first install and did some things different the second time. I built stands that pivit around under the cross frame to set tongue jacks on. I won't get under the vehicle until I have done this. Very stable this way. All in all it has been and continues to be a good lift. I have also built heavy large jack stands(not the red ones in the background in the picture) that will support the vehicle while it is lifted, then I lower the hoist and I can do brake jobs etc.
excellent. Thank you. Do you mind clarifying several points to me:
1 What do you mean by:
I built stands that pivit around under the cross frame to set tongue jacks on. You are supporting crossmembers preventing them from accidental fall? Does Worth lift feel that much insecure?
2. Worth says their lifts are free standing design. Which is - they are supposed to be stable without concrete anchors. What is the post wall thickness? I am not sure, if "inside the post" slides are strong by design
3. Any plastic parts inside or on the slides?
4. How much are safeties engaged on the locks? It has post welded "steps" for safeties, right?
5. Is it Worth lift in this video?
As it looks awfully like it, but Worth refused to confirm it.
