Would 8/2 Romex fit a 20amp breaker?
wazzabie
I would like to repurpose a dedicated 8/2 Romex line that currently has a 30amp double pole breaker. Would 8/2 Romex fit into a 20amp double pole breaker?
dcg9381
Austin, TX
Some of them will. Post up your breaker type, it's usually in the breaker spec.
W
wazzabie
Update: The 8/2 solid wire romex would fit the 20amp breaker however it is not rated for the 6-20r outlet.
mm08822
The answer provided in post 4 was based off of product spec.
This thread content could have been part of the welder recept q.
mm08822
It's 10 gauge if that is the orange nm-b shown in the garage pic with the panel that has the missing 🦵.
Maybe I'm just out on limb with this one.:unsure:
PCustoms
VT
Damnit, I had to go check and see if that thread was a different OP (it was).
This OP sure does have a lot of electrical threads this month...
Cruzan80
Denver, CO
Its black jacketed. Must be 6/2 Romex then.
Color doesn't always mean sizing. There is not a "rule" for those. Are you sure it is Romex? A quick look with a ruler could tell you a lot (10awg is just bigger than 3/32, 8 is very close to 1/8, and 6 is between 5/32 and 3/16).
sparky 1971
Central Iowa
The conductor size doesn't matter. It could #8 or #6, neither one will fit on the receptacle without pigtails and the only solid wire is the #10 ground.
mm08822
Whoops, I was out on a limb or off in a cloud.
ehcsrop
Lakewood, CA
Isn't this Garage Journal Electrical College?
IF I log 4000 hours here do I qualify for a residential cert in CA (and similar reciprocating states like NV and AZ)?
lol no
hours only count as a registered electrical trainee (have to be signed up for school) and hours have to be verifiable via payroll.
sparky 1971
Central Iowa
lol no
unfortunately you dont work for the IRS who is the one that has to provide them
These new rules sure take the fun out of everything. I had one year of apprenticeship where the emphasis was how to use a code book before I decided to move to TX and party. The contractor I worked for down there didn't have any affiliation with a school so I was pretty much taught in the field. After two years, on a dare, I took the Journeymans test and passed. I was back in IA visiting one weekend and I told my dad, an attorney, about it. He voiced his opinion about it being a bunch of **** that I still had to work another 1-1/2 to two years before I could get a license. About a week later I got the mail and there was a notarized affidavit from his office that I had accumulated 8000 hours of work experience and I went and got myself a Journeymans license. I did already have a residential license down there, all one had to do was pass a test, hours didn't matter. This would have been in 1995-6ish. Moving back to IA in 1998, all I had to do was retest, didn't need to prove anything because I was already licensed in another state even though by then I had plenty of hours.
mm08822
Well that splains it all. Not a single mention of a broom operator's license.
(Or ya failed it and won't fess up. Maybe that's why you moved back.)
sparky 1971
Central Iowa
Dammit. I did skip a couple of nights of classes during my one year. I think you just figured out the subject matter for me. I had helpers to push the broom around, I moved back 'cuz it was too effing hot nine months out of the year.
dave*99
Coastal NJ
Things have changed recently. Helpers have become quite demanding of tool upgrades.
