signcrafter
- Joined
- May 9, 2012
- Messages
- 12,684
I have a two car garage that is drywalled. Outside it's in the single digits and below all week and inside the garage in the morning it's around 30 degrees. I have a little Kerosene heater that does an alright job heating the garage all things considered, https://www.homedepot.com/p/DuraHeat-23-800-BTU-Indoor-Kerosene-Portable-Heater-DH2304/100045793.
Just wondering if putting a box fan behind it to help move the heat around better would work good or if the fan blowing would cool the heat off? If that even makes sense. Right now it takes a few hours to bring things up to 40-50 degrees which is comfortable to work in. I usually have the heater in one corner of the garage. Not too bad but if putting a fan behind it blowing the heat around the garage would help warm things up faster that would be great.
This is about as bad as it gets for the cold and was surprised to find the heater do much at all. But when it's 20-30 degrees outside the garage heats up pretty fast and is very comfy to work in.
