would these work for my garage
bowanna03
I have been searching on clist and cam across this si this a good deal and would this work for my garage my garage is 30ft wide by 26' deep and have 12 ft ceilings. they are ge hi-bay light fixtures, 32 inch diameter, damp location ok, w/ some 400 watt sodium bulbs. only about 17 left. used but good condition $20.00 each or $275 for everything including spares
v8garage
Texas
Check to see how much the replacement bulbs are. I got a "good deal" on some lights like this once and found out later the bulbs were about $70.00 ea. and were hard to get. May not be the same case with yours but I would check before I bought them.
V/8
nadogail
Coronado, CA
In addition to the comments by others about the size of the fixtures as they relate to the size of your garage; what about the yellow color of the light and the time it takes for the fixtures to "warm up"?
I personally have never seen High Pressure Sodium lights used with such a low ceiling.
bowanna03
What would be good to go with that is affordable and how many should I get, thanks for all your help guys I do appreciate it.
35mastr
Norcal
If these are the really big round ones that are used in the shops.
They take a while to fire up. If its cold in there they take a longgg time.
nadogail
Coronado, CA
Make sure that the Ballast voltage is something you have available.
A lot of them need 277 or even 480 volts.
mrb
those fixtures are for ceiling heights from 20ft to 40ft. The are not hard to find and can be had by the pallet for practically nothing. They only cost a hundred and something brand new. They have a 10-20 minute restrike time (if you turn lights off then back on), and a 3-5 minute initial warmup time. You dont want them
With a 12ft ceiling, just get a ton of 4ft T8 flourescents.
rinny_tin_tin
Northern Virginia
Scarf em up. For $20 a piece..buy them all. Try them - they will work fine even with a 12 ft ceiling - although bright. Sodium bulbs are cheap and last longer than MH. If you don;t like em - you can sell em for $50 each w/o problem
Charles (in GA)
50 mi south of Atlanta
Sodium is the orange light used on many outdoor lights, such as "street" lights. Our aircraft maintenance hangars at work have used sodium for years, and it was very annoying. Recently they changed over to MH bulbs. Apparently there is a MH bulb that can be directly screwed into a Sodium fixture, and that is what they have been doing. What a huge improvement!!!!!!!!! Much brighter, white light.
Those fixtures will not be worth a **** in a 12 ft ceiling. You will lose 2 ft of useful height as the fixtures will hang down at least 2 ft from the ceiling. The light is so focused that you will have dark spots. Best for a garage of your size is 4 ft t8's.
Charles
bowanna03
Thanks guys I am gonna go and buy some 4 ft T8's how far should I space them out and how many do you think I will need. should I buy hardwire ones or should I just plug them in and if so how many can I plug in to an outlet.
35mastr
Norcal
If anyone is looking for these High Bay lights.
I have them by the pallet.
Our facility just changed over to more effecient lighting so that they could get a kickback from PG&E.
They are all in working condition and clean.
