mcj115
I have this radiator which was removed from my houses off peak heating system when I replaced the HVAC a few years back. The radiator measures is 20"x 30" x 3" the input and output lines are 3/4" and the radiator has a copper core.
Would it be safe to use this as an air compressor after cooler which has a max pressure of 135 PSI? As this was designed to hold hot water at lower pressure I am sure of the risk if any of putting it up to 135 PSI.
I assume I an just solder on NPT fittings to make this part of the overall compressor system
