nate379
I have a run of about 90ft from my garage to the shed where the compressor will be.
Rubber air line is going to be around $3 foot. This stuff is $1.06/ft and shipping is going to be about $40.
McMaster
50375K59
1" ID, 1 1 / 4 OD, 1 / 8 wall, max psi 152 @70*
• Wall Hardness: Hard (Shore D: 65)
• Use compression fittings (see pgs. 145-159)
• Tensile Strength: 3900 psi
• Flexible
Temperature Range: –100° to +180° F
Even though no extra reinforcement has been added, this highdensity
polyethylene (HDPE) tubing can withstand high pressures as
well as vacuum up to 29.9 Hg @ 73° F. This tubing is made without
a plasticizer that can contaminate fluid passing through, so it won’t
impart tastes or odors. Use with water, air, food and beverage, and
ethylene glycol. Material is FDA CFR21 177.1520 compliant. It can
be sterilized with gas and chemicals.
To Order : Please specify length from the available lengths listed.
McMaster
50375K59
• Flexible
