would u take on a quincy 350 compressor??
sandmanxx
North Pole
Would you take on a 350 compressor?? I mean make a setup. Man those are heavy and big.. But sweet!
I can see it now - someone saying show us your compressor.. I have a 350 hooked up to a 60 gallon tank :drool:.. Hmm make a seperate roll around and connect tank to compressor roll around..
GeneralDisorder
You need the power to run it - which means 3-phase typically. Do you have that kind of power? If you do then a 350 is a GREAT pump.
A 350 is a nominal 10 HP pump. You simply can't run that in single phase and don't even think about using a rotary phase converter - you would need a 15 HP and they don't work well for non-constant load applications like a compressor....
As for "taking it on" - sure I've built many, many compressor packages with 350's. Pretty standard for industrial settings. Built a lot of rental machines for the vineyards here in the valley.
GD
S
sandmanxx
North Pole
GD
Well Thanks.. The single phase motor was one of my questions.. No I would never think of a converter.. so you are telling me a single phase 10HP motor wouldn't work.. do they even make those for compressors lol..
What makes them not work well for non-cont. load applications.. What about a 310 or 325 then?? Single phase again!
Chris.Santamarina
New York
MMMMM 5120.....
When my IR pump gives out I'm putting a 5120 on the 120 gallon tank it's on now.....
There is no other machine quite like a 5120.
GD
325, 350, 5120............... Its a Quincy, you cant beat the performance, longevity and overall reliability of any of their models (Except the new models since being bought by Atlas Copco). I probably see a dozen or more Quincy rotaries a week and most from the early 80's that havent had a lick of problems since purchased. In 16 years in the Air Compressor field you will not find a better designed or built compressor. And for the record I have never worked for a Quincy distributor, but have had the pleasure of aquiring plenty of the end users as customers. Fantastic piece of equipment.
Chris
GeneralDisorder
They do make 10 HP single phase motors.... but they are in the neighborhood of $800 to $1000 and they draw a whole lot of amps. You would need a hefty circuit to run it on. 7.5 HP is really the largest single-phase compressor you will see on the market due to the high starting amps (6 to 10 times the nameplate FLA) and very high cost of such motors.
Rotary phase converters are most efficient when tuned for the amperage draw (load) of the device they are driving - for a given amp load you need to tune them to balance the phases..... A compressor increases it's load as a function of pressure. Thus tuning the converter is difficult since there is a wide swing in the amp draw.....and so you have to oversize them a lot to get enough power out with them unbalanced across a larger percentage of the amp differential.
325 is the holy grail of home shop compressors. More air than most people will ever use - one could easily keep up with a two man body shop. Perfect size - they fit a 5 HP saddle like they were made for it and run easily on single phase power. Overall they are the best choice - but much like small lathe's and mill's they command a higher price than larger machines because most people can't devote the room or have the ability to run the larger machines.
GD
GeorgiaHybrid
Extreme NW Georgia
I have a 325 in my home shop and couldn't be happier with it. Hard to beat a Quincy QR-25 series compressor but as noted above, the 325 hits the sweet spot for most people.
rodm1
Most pumps I've seen will run with multiple size motors. Check with Quincy I bet you could use a 7.5HP with that pump you will be vary happy you did.
