Wrenches found in box
Shoottx
Plano Tx
Found these two in box of stuff on the shelves. I have no idea where they came from or what they are for. Any info would be appreciated.IMG_3495.jpegIMG_3494.jpeg
iamhomeless
Indy
Well the top wrench is an older williams, can't make out the markings on the other one
Al Borland
Top (Williams) wrench looks like it's for square head bolts. Perhaps a "Station Tool" like the ones we used to keep at the metal lathe for the bit stand/holder or on the shaper.
cherrybomb
Near Madison Wi.
Like Al said,usually square bolt heads were very common on the manual lathes in the machine shop.The head thickness was much thicker than a combo wrench for instance as you kind of backed up the wrench with your fingertips on both sides of the head of the bolt
Shoottx
Plano Tx
Yup, all of this came out of a machinist estate sale. More to Identify as it goes. On the wrench after a little more gentle cleaning it is probably MO-LYBDEN-UM, The other end is marked 1033-C
So the question is this a special wrench or what?
