NeedsXtraspace
Clutch Pilot Bearing Puller Or a comparable model. Thanks!
I don't have the tool you need, but someone on here recently described a method for removing that bearing that did not require a special tool...just used the hydraulic pressure of grease to pop the thing out. Just an idea if you only have one bearing to do.
I rented a Pilot Beearing puller earlier today.... maybe it will work out better than the grease. Gotta get my car back on the road!
The grease method works best with the solid bushings. With the needle bearings, not so well. I looked that puller up, just to see what you're looking for. It looks like it would do a good job. I've used a slide hammer and a single hook, but that is somewhat iffy, too.
I stumbled onto these on ebay. I may get myself two of them. $44 for 2 different sizes.
